Hayward Main Drain Grate Replacement
Oct 1, 2010
12
Odessa, TX
The drain cover/grate on my in-ground pool crumbled apart and I'm struggling with finding a replacement. The markings are fairly clear and reads "SP1048-C." The grate measures 6'5" and has 2 screw holes. It sits flush with the bottom of the pool.
Since everything else was originally Hayward, it seems reasonable to assume the same with this part. Searching the Hayward site didn't seem to get me anywhere. Anyone have recommendations for a replacement?
Rob O.
This should point you in the right direction.....It appears that grate has been discontinued as non-compliant and replaced with this, though you'll need some more snooping to nail down the size and color.
Rob O.
The Hayward wg1048-E
