I have a Hayward heater (not sure what model, but has 5-6 burners). The original setup linked to iAquaLink was done by the previous owner. Everything worked find controlling the system until I had to clean out a burner line due to a spider web in the first burner’s “pipe.”
Thereafter, whenever I turn on the pump system in iAquaLink (this works) and then turn on spa mode (this works), if I then try to turn on spa heater, the heater turns on but the display on the heater indicates pool heater mode. As a result, the spa only ever heats to the pool temp setting. (I have tried going into BO mode but then the heater never turns on thru iAquaLink controls.) In order to make the spa heat to the spa heater setting while the system is on, I must manually click the Hayward heater out of linked mode (linked mode = orange light on the power symbol; unlinked = no light) and instead put it in manual spa mode (red light on spa symbol). Before turning off the system in iAquaLink, I have to manually switch the heater back to linked mode. Otherwise the next time I turn on the system, the heater automatically turns on to spa heater mode (the last manual mode).
How do I reset the heater to correctly respond to iAquaLink heater selections (pool vs spa)?
Note: the pool heater setting in iAquaLink correctly turns on the pool heater.
