Followed the service guide and it certainly seemed as though the gas valve was at fault. There was zero smell of propane at all and everything else seemed good after receiving the "IF" error code. I switched out the gas valve and now I do smell a little propane when it tries to fire, but nothing else. Managed to get a borescope through the viewing port while firing. Pictures attached. Looks like the ignition is heating up. Is it supposed to do that or is it supposed to spark?
Also, are the burners supposed to be surrounded by blackish gravel or is that immense amounts of buildup? Trying to figure out what else could be wrong or if it's just in need of a serious cleaning since I'm still getting the IF code and it won't fire up.
Help???
And through the flame sensor port.
Help???
