Yea, If I call a service Tech I expect to stay with them and call Hayward. The Hayward Tech gave me his personal extension for the service tech to call after I told him I did not expect much more from the service rep other than what I have accomplished with help from this you and this board. Unit operates even more than your summary as the gas lights at the burners but only stays on for 5 seconds or so. What keeps me going is this service cycle works so perfectly up to issuing the IF error. Everything works, it just shuts down after 5 secs.
Summary operation is:
I turn on Spa pump to initiate call for heat. The blower starts on low speed. After about 30-40 seconds (manual says 40 seconds), blower changes to high speed and gas ignites (Green LED comes on, exhaust is hot) but then after a about 5 seconds, flame goes out, blower returns to low speed to (Green LED goes out, exhaust is cold). This repeats 2 times then IF code is issued. I can restart this cycle by incrementing Mode to Spa or it will repeat the cycle endlessly each hour as long as Spa pump is on.
Btw, when I first start the cycle, error code HS is also being displayed. This is Maximum return water temp alert. I believe this since the water has been sitting in the AZ sun that can bake cookies! It clears soon after the water flow is established.
So what shuts it down?
I was going to hook my Volt meter up to the Gas Valve and see if the voltage is interrupted at 5 secs.
Thanks.
Thanks.
