Thank you in advance for any guidance. Thankfully my pool has largely been "trouble free" due to this forum, but 10 years of operation are starting to take its toll. Issues that I am seeing are as follows and trying to figure out the best way to troubleshoot:
- Recently started having the primary pump "short cycle" and automatically turn off when running manual (after about 30 minutes). Secondary pump will run in manual with no issues.
- SWG (T-15) says there is no flow, so it is not working. It is also several years old, so probably needs to be replaced anyways.
- The heater is also being called to turn on even though it is set to manual. At this time, I turned off the heater.
