Hello, new member from middle GA. I've been lurking here for a couple years.
We bought our home in 2019 with an inground pool and inherited a Hayward SWG system in it's 3rd season.
Every year it's been something. New control panel, new salt cell, new main pump, rebuilding Polaris cleaner and this site has been helpful in tracking everything down.
We bought a generic replacement T-15 cell from a year ago for a little over $300. A couple weeks ago, there was a no cell power message on our Aqua Logic board and 4 of the prongs on the SWG connector showed burn marks. They said their 5 year warranty didn't cover it and my board is what caused the problem. I swapped the power cords from my dead Hayward T-15 with the replacement and got the 10.08 amp high salt reading and it shut down after 15 seconds.
Went ahead and ordered a new generic replacement from Leslie's and it came today. Same high salt reading. I've been concurrently doing more research here and learned more about the K-1 relay on the main panel having a short issue. When I saw the Leslie's SWG not working, I pulled the control panel off, checked the 20 amp fuse which was melted and fell apart in my hand, and swapped it out to no avail. Next, I pulled the control panel and the main circuit board off, making sure to take lots of pictures of the connections, and sure enough, there were burn marks and a hole in the K-6 relay on the back of the board. Put a little solder on it, and bam, everything works! Kudo's to all the 9-10 year old threads that shared this information!
BTW, my Hayward sand filter had a leak in the seam at the top near the collar like they usually do. JB Weld has never worked for me ever but it did this time. I got the high heat epoxy for water like you'd get to fix a radiator and so far, so good. My son who's a plumber along with 99% of what I read on the internet said it wasn't fixable and I'd have to get a new one. I'll post again if it fails anytime soon. At least it's bought me some more time as I'll probably need to replace my booster pump now. It's always something with Hayward evidently.
