I am having trouble with high FC levels.
I’ve always been able to run SWG at 10% in my 15,000 gallon pool and maintain FC level 1-4ppm.
Ever since May my FC levels are spiking to 9-10 ppm even at 5%. I’m having to cut off SWG to get FC levels down but when I start back it quickly goes to 9. And I am not superchlorinating. I run the pump 6 hours…8 if lots of swimmers. The salt cell replaced last year and the pump this year.
I use Taylor pool test kit and my numbers are:
PH 8
FC 9.8
CC 0
TA 100
CH 240
SALT 3200
CYA 52
CSI 0.19
TEMP 82
It takes everything I can to get PH to 7.6-7.8 bc of it being a salt pool and we have a spa spillover. When PH is 7.8 the CSI is right near 0.00 but that’s adding acid a little each day.
Regarding high FC levels could the control board on the Hayward be broken/shorted out and not regulating the correct desired output level. I did notice the control box was hot the other day and it’s mostly in the shade all day.
I’m pretty obsessive regarding my pool chemistry and this is driving me crazy.
Any thoughts would be very much appreciated!!!!
Stephanie
PH 8
FC 9.8
CC 0
TA 100
CH 240
SALT 3200
CYA 52
CSI 0.19
TEMP 82
Stephanie
