hayward aquarite pro no lights or display 3 month old unit
The first picture is set to 115, the second picture is set to 230.
20200424_135229-jpg.327332
I think mine are still set to 110v, but it's been running ok like that since last year.
Readings:
26.74v
5.69a
81 degrees
The current diag readings are:
~27.2v
~5.87a
Check your input voltage with a meter.
If the voltage is set wrong, the DC voltage will be wrong.
Your DC voltage is OK, so I suspect that the input is 120 volts.
You're right, I must be losing my mind, input is 120v. Maybe its the 90 degree heat here in PA the last two days getting to me. For some reason I thought I was running 240v.
Apologies to the OP for hijacking!
Reactions: JamesW
