I have an Aquarite SWG and it's been working fine with no issues since I've owned it. I got all my chemicals balanced this year and according to my test strips (I did the test 3 times as I was adding salt to it over the week or 2 in May), I have 3120 ppm. A couple of weeks ago, I disconnected the power to the SWG and other pool equipment as I replaced an electrical outlet. When I turned things back on, the SWG had a reading of 0 salt and wouldn't generate, showing blinking lights at "low salt".
Through troubleshooting, I was able to use the instant salinity to set the current salt back up to 2900. This has since lowered to 2700 and has stayed there. According to the system lights, it's generating chlorine, and if I turn it to super chlorinate, the light for that comes on as well. There are no errors, and when I turn the system on, it still has an audible click as it starts running a current through to generate chlorine. However, last week the pool got cloudy, and when I tested the FC, it was near 0. I manually added chlorine, and since then, I've had to continue to add chlorine manually as the SWG is not actually producing anything.
I've tried various things like turning it to 'off' and back on, using super chlorinate, triple checking all my pool chemical levels, and disconnecting the power cord to the cell, and nothing has fixed it. So I'm wondering if my cell is shot (maybe the power outage shorted something out?), or if something else has to be re-calibrated, or if there is a way to 'kickstart' the SWG into producing again. The manual and various videos/forums I searched over the last few weeks haven't gotten me anywhere.
Thanks!
Thanks!
