Interesting! But how did you calibrate the cell if the reading is 0?
On a known good bd, the relay should click even if the cell is disconnected as long as the switch is in Auto. The relay should click approx 10 seconds after the Generating LED turns on. Your cp's stopwatch might come in handy.
The average salinity reading must not be at zero. Hence, the error! Try to perform the recalibration within seconds after the relay has clicked. Before the relay is about to click, move the switch to display the instant salinity reading (-0). When you hear the relay click, quickly move the switch to Superchlorinate and back to Auto.
To verify if the relays are working, measure the DC voltage between the A and B terminals. It should read 30-32 Volts DC after the relay has clicked and then go back down to 0 and faulted.
