Hello everyone, I have a small leak from my Acid dispenser injection valve (CAX3511) . I unscrewed it and went to put it back in after wrapping with Teflon tape and the male portion of the injection valve snapped right off. After getting a replacement and some rectorseal T plus 2 I got the part in but still had a leak. Went to unscrew that and it broke again. I feel like the threads in the plumbing are off as the part rocks slight when screwing in and taking it out.
Is it possible to use a brass fitting to plug that 1/4” hole in the plumbing for now so I can run my filter? The injection valve is not very easy to get apparently. Any guidance would be appreciated.
