Hi --
So, my 2009 Hayward S244T developed a bit of a leak where the Vari-Flo top meets the top of the tank, and you use the clamps to seal it.
I needed filter media replacement anyway, so I took off the Vari-Flo top off to replace the sand with Blü Filter Balls, and added three unions on each of the three PVC pipes while I was at it. All of my unions work perfectly— zero leaks; but where the tank meets the Vari-Flo valve, it's still leaking when on "filter" mode. The pressure is a bit lower, due to the new media, and the fact that it's not yet dirty. I replaced the diverter with a brand new one yesterday. I also replaced the rubber "O" ring that goes on the Vari-Flo valve. The old blue one was worn out. It STILL leaks, right there where the clamps tighten. I literally cannot tighten them anymore than they are already.
I took the clamps back off, and put a silicon caulk around the entire joint. STILL leaks. All I can figure is I may have inadvertantly moved the tank when cleaning out the old sand, and now the top of the tank is just not flush with the bottom of the Vari-Flo valve... ?
Is there another type of gasket that will make a better seal? I'm at my wits end. I only use Hayward parts so that I know they fit properly, even though they cost more than the aftermarket stuff.
TJW
TJW
