Hayward 2 Speed Filter Only Operating in Low Speed
Jan 15, 2019
32
Morgan Hill
We have a big storm coming in CA and I am out of town. We have someone staying at the house and I walked them through the process of draining the pool water from the water spigot. Unfortunately, when I turn on the filter from my app on the phone, the filter will not turn on "high speed" its stuck in "low speed" - any suggestions on troubleshooting? Would the water level being too high not allow the pump to be in high speed?
What APP are we discussing?
I see no automation listed in your signature.
No.
Possible cause: wire for the "high speed" has burned/come loose, either in the motor or at the relay (terminal 2 in the motor), 2-speed relay not functioning, high-speed circuit in the motor has become damaged.
Not sure what automation you have. Water level makes no difference.
Bare with me, as I am new to trying to solve equipment issues, ha!
I have a 2 speed Tristar pump and the pump will not operate/turn on when the filter runs on high speed. The filter seems to work fine on "low speed" but I am not able to run the pool sweep or pump out water without the "high speed" running. Below is a picture of the equipment.
I am using the Hayward AquaConnect app.
Just received 25-10 cap - installed and high speed works fine now.
