I have this combo from about 8 years ago or more maybe..
The 1.5hp pump, i have had the plug from the pump going into a 2 port outdoor timer, now two diff models.. both times the plug got melted and the gfi plugs reset as a result. (the plug on the pump sortof melted and the pump plug blackened)
I did notice yesterday as i wiggled the cable it seemed to shut off..
I looked inside at the 3 wires and i cant seem to pinpoint the issue or for that matter where they connect. I also cant seem to find a relevant video on the pump and wiring.
At this point i bought a new power cable and will try to figure out where the connection points are, hoping this fixes things.
Does anyone have any thoughts as to why this might be happening? For now i have it directly into the power outlet, no timer. Not sure if the timer is even the culprit since moving the wire did cause a fault, i think maybe grounding issue.
Amazon.com
www.amazon.com
