- Mar 31, 2022
- 77
- Fiberglass
- Pentair Intellichlor IC-20
I just installed a new Intelliflo VS pump on our pool. Using the Intellicenter web portal, I created some feature circuits for the various speeds I would like to use. If you then go to pumps and add the VS pump and then add the circuits all is well. However once you save your pump setting the first time, if you go back and try to add another feature circuit, when you click the orange down arrow, the feature circuits do not appear in the list of available circuits to choose. The only way around this is to delete the pump and start over again. Is anyone else experiencing this? Is it a bug or am I doing something wrong?
