The 10 CYA level and the rest for that day came from the pool company doing the testing so no I'm not sure if that was accurate. They are the ones that told me to do stabilizer and acid. I did have tablets in the skimmer and floaters but removed them like was told here and to only use bleach. That's when I started seeing a true difference and yesterday was the first time I could see the bottom. It's not completely clear yet but now you see a change.
Now that I have the good test kit readings will be more accurate.
I will take the time to re read all the recommended things like pool school again and figure out this whole pool math thing.
I appreciate everything
L
17,205gal, 27x52 AG, 300lb Cristal-Flo II sand filter 145362C, 2hp Dynamo 2speed pump DYNII-N2-2, Install date June 2012, Hayward Aqua Critter ( have not used )
L
