If you tested at 22, your SLAM level is 20 so you need to add 0. The 20 number comes from the CYA/Chlorine chart that I linked earlier (see Shock Level on that chart). THAT goes in the Target field during SLAM. The target listed on the Pool Math page is for normal maintenance. For when your pool is clear and has passed all the SLAM criteria. For now, until you finish the SLAM process your target is always 20.
It is confusing but Pool Math only gives recommended normal operation levels. In the SLAM process you use the CYA/Chlorine chart to determine your shock level FC target.
