My filter pump is not on a schedule. It's on 24/7
What's in the Schedule screen in iAqualink?
The part about "Whatever is scheduled will happen when you schedule it." There are exceptions to this rule. If the system is in Spa mode with the Spa running, it will NOT activate the Spillover, even if it's scheduled to do so.
That explains why I have such a big air bubble that I can't even see what's in the pump basketIf I remember correctly, you can't actually set something to run a full 24 hours in Aqualink, but it's been a little while since I've messed with that screen. My pump tends to get a big air bubble after running most of the day at very low speed, so I'd rather it reprime anyway.
While we're discussing priming... I lowered the priming speed a little. Mostly this was an arbitrary choice, I had a gut feeling that letting the pump run at max was both 1) unnecessary and 2) potentially causing unnecessary stress/wear. I'm not sure if any of that is true, so I want to ask about it here. At the current speed my pump has no issues priming. Screenshot of the current speed is below. Should I keep it how I have it? Change it? If so, to what?
I never changed the priming time. I assume `:01` is minutes not seconds. I am not sure what is factory default versus what my PB set it to.Agreed, I kept the default 3 minute prime for when I open up my pump to clean the basket. I don't remember what the original prime speed was set to.
My pump model is in my signature. Should I set it to speed 3500 max, prime speed 3500, and set to :03? I'm not sure how you tell how long the priming speed needs to be. :01 seems to work for me, but again maybe I'm not seeing an issue.
