Have to decide by tomorrow - key questions for build consideration
Barregal5
3
Very SW Florida
Hello experts - it's a long story why but we have less than 24 hours to make this decision between our 2 finalists. I've made a comparison spreadsheet and would absolutely appreciate your expertise on some items where as new pool owners we aren't sure.
We are 3 miles from the ocean and near a large conservation area, if that matters.
We went through both proposals and some, but not all, the fine print and below are the questions. I will try to make them really clear and only choose the ones that seem to matter a lot vs aesthetics. One company is a bit more costly than the other but we want to avoid expensive repairs down the road and also, dumb choices :)
Pool is 15x30
No issues w design
We may screen it in so we'd have to include the footers
1. Pump: Jandy 2.7 or 1.85?
2. Filter: Jandy Pro DE no cartridge or Jandy w Cartridge?
3. Lighting: Jandy plastic or glass?
4. Salt system: Jandy Aquapure
5. Electric heater: Jandy Versatemp or Aquacal South Beach?
6. Gunite or shotcrete?
7. Thickness of shell - seems to be a competitive thing, what is safe and what is overkill in this area?
8. Timer: Jandy Pro Aqualink
9. Skimmer: Recessed w gunite and steel wrap or Turbo self adjusting w large basket
10. Drains: 2 anti vortex antip entrapment
11. Piping - anything to look for here?
12.Valves - Jandy Neverlube or other?
13. Eyeball inlets - anything to look for here?
14. Solar recirculating system - anything to look for?
15. Time Clock for filter - anything to look for?
16. Warranty items to look for? Both have "lifetime" on shells, any other key warranty items, other than standard mfr warranties?
17. Pool plaster warranty against cracking, streaking, etc - I thought certain plasters weren't susceptible?
18. Beveled v non-beveled pavers?
That's a lot I know but we are so concerned about making a mistake with our choice and need to know what's not 6 of one, half a dozen of the other. I'm sure you all understand.
Thank you so much! :cool:
Welcome to TFP.
2. Filter: Jandy Pro DE no cartridge or Jandy w Cartridge? Get large cartridge filter 300-500 sq ft - bigger the better. Not a dinky 150-200 sq ft filter.
3. Lighting: Jandy plastic or glass? - Infinite WaterColors Nicheless LED Lights | Jandy
4. Salt system: Jandy Aquapure 1400 cell, not 700.
5. Electric heater: Jandy Versatemp or Aquacal South Beach? Whichever one has local repair service
6. Gunite or shotcrete? Either one equally good.
7. Thickness of shell - seems to be a competitive thing, what is safe and what is overkill in this area? Engineer with his stamp on the pool drawings should specify. Thicker the better.
8. Timer: Jandy Pro Aqualink iAqualink RS8, not PDA.
11. Piping - anything to look for here? lots - read Equipment Pad Best Practices - Further Reading
14. Solar recirculating system - anything to look for? Solar Pool Heaters - Further Reading
15. Time Clock for filter - anything to look for? Not needed with Aqualink
16. Warranty items to look for? Both have "lifetime" on shells, any other key warranty items, other than standard mfr warranties? Warranties are pretty worthless
17. Pool plaster warranty against cracking, streaking, etc - I thought certain plasters weren't susceptible? Pretty worthless
18. Beveled v non-beveled pavers? No opinion
Welcome to TFP.
Thank you for the amazing reply, so appreciated. May have follow up questions in morning. Head is spinning!
No just the opposite. Gunite can be manipulated at the nozzle with the amount of water added, not with Shotcrete. In my experience shotcrete is far superior than Gunite. Shotcrete typically has less rebound (a byproduct of application that should never be reused). Shotcrete is mixed at a concrete plant by a computer to very high standards. Gunite is mixed at the job site and can be changed to best fit the conditions for application (weather or a under staffed crew), this is done by over hydrating the mix at the nozzle and can possibly take the mix out of specs.
This is just my personal experience.
