I have a pentair 420 cartridge filter. I'm pretty sure my filters do not require DE, but they look just like yours. What's the difference?
Hi. We have really old normal filters that need replacing. Would you recommend getting a quad DE filter system instead? What are the benefits over standard cartridge filters? Thank you!
Air relief valve leak....another trip to Leslie's for a new air relief valve. Leslie's price, about $42. Price I paid 2 years ago on Amazon with FREE shipping and SAME-DAY delivery, $28. Grrrr....Leslie's got more of my money. So it looks like I'm getting about 2 years out of these air release valves as the plastic housing where the pressure gauge screws into cracks and leaks. And NO, I am not over tightening the male brass pressure gauge into the plastic female threaded opening...just a poor design and not enough reinforcement around that area.
Season 5 UpdateI have decided that when this filter needs replacement (either with a cracked lid or when the internal quad cartridges go), my next filter will be a Clean & Clear cartridge filter....no more DE for me.
Season 5 Episide 243 (I should get Netflix to pick up my story and turn it into a show)
Clarity restored!! After 36 hours of continuous circulation and filtering (and 3 rounds of manual vacuuming....and a half dozen sweeps with the wall brush....and running my robot three times), I can see the Phillips head screws on the main drain cover....wait, are those Torx, arrrggghh Torx!!! OCLT at 10ppm passed so the chemistry, aside from my sky-high CH, is all good.
The filter pressure is not where I’d like it to be though. It’s a few PSI above where it was last year and I think it may have to do with whatever the Leslie’s DE stuff is. I’m going to get a different brand of DE but not backwash until after Friday when the tile guy shows up to knock all the light scale off the spa face and bathtub ring. Since I have to drain the pool down to the bottom of the tile line, I’ll use a combo of backwashing and my submersible to drain the pool.
I appreciated (and paid handsomely for) having the parts available at the Leslie’s pool store 3 miles down the road but I’m not at all impressed with their DE. I don’t know what the difference is but I half-wonder if they didn’t have some kind of additive in it to lower the dust levelAnyway, this too shall pass....
Torx?? Close but not quite, when your water gets really clear you will see a small bump in the center to prevent a torx driver from removing the grate.
“Security” driver, take a close look at public hardware or anti theft license plate hardware & you will see the epicenter bump buried in torx like
hardware.
Was your builder a paramount dealer??
**** I’d find it bizarre if license plate thief wasn’t equipped with a security style driver, just sayin’
I prefer the one-way security screws...you can only tighten them. As for the security Torx, easy-peasy lemon-squeezy - just go get a set of Gra-Bits and drill those suckers right out ....
Actually my drain covers have standard Philips head screws, no security needed. Apparently my pool builder thought I was intelligent enough to not mess with the covers...boy was he wrong!
I was thinking along those lines also however I wish I could just replace the internal guts from DE to Cartridge. Do you know if this could be doneSeason 5 Update
I was thinking along those lines also however I wish I could just replace the internal guts from DE to Cartridge. Do you know if this could be done![]()
