- Jun 1, 2018
- 13,838
- Vinyl
- Hayward Aqua Rite (T-15)
My kinda setup! All the right stuff…
well placed bungees, , kudos
May I ask why you decided to go with the "regular glass media"?...my regular (glass media) filter...
Water is blue. Very light blue, but blue nonetheless.I don't know if the blue water that remains is normal, but this blue looks as close to transparent, doesn't look obviously blue in a white bucket, and the water is looking "sparkling" now where it wasn't really before. I don't know how much of the original copper blue might have carried over post refill, possibly almost none and all I'm seeing is the sky. Cu in the water is now measuring 0.04 on a Pool eXact EZ (which has an advertised 2% tolerance on Cu), whereas pre-drain I was at 0.48.
Sorry I see I totally stuffed up my reply.I'm facing a metal stain fight or flight at the moment. So i was just looking at Sydney water annual report and they indicate the avg level of iron in our tap water was 0.012 and copper 0.021 last year. O.k you're in Melbourne, but it makes me wonder why are you pulling so much metal out of your fill water?? And why was my fill water that ugly colour too??
Metals testing is the only testing we suggest having done at the pool store.Sorry I see I totally stuffed up my reply.
When I first made my post I mentioned (and then deleted because it seemed odd), that the tap water next to my pool when I tested it was 0.12. There are a lot of copper pipes in my place, and I suspected that reading was either (a) because the Pool eXact is not reliable or (b) the water had been sitting in copper pipes for a while. I went to the tap next to the meter in my street, ran it clear for 2 minutes and tested again and it came back as 0.00. Of all the things the Pool eXact EZ does test, the most reliable (at an advertised 2% accuracy) is copper.
Regards what was in my water and making it look green. I know if I pour a 20L snow-white bucket full of my tap water it has a green color to it. What that's comprised of I have no idea. Is there an affordable place to do a full water workup including iron?
Lastly, all I can say is that the polyfill worked a treat for getting "rusty orange" stuff into it, and now the pool water looks amazing.
I got a brewing water test from Ward labs. They have home tests that include iron. Copper and some other stuff can be selected as add-on tests.Regards what was in my water and making it look green. I know if I pour a 20L snow-white bucket full of my tap water it has a green color to it. What that's comprised of I have no idea. Is there an affordable place to do a full water workup including iron?
@CRAD_oz, I'm looking at this with the ASP module to control PH and FC. I assume this is a similar if not the same system as your PureSilk as PoolPower appear to make cells for PoolLab, PureSilk and Hayward. Their manual says "FC should be between 1 and 3" and "Free chlorine levels above 4.0ppm may void manufacturer warranties on your equipment.".Or this one @45g/hr. POOL LAB PL45 SALT CHLORINATOR
GreenJust wondering if the ASP lets you go above a target FC of 3 (so I can run CYA at 70 and FC at 5) and if TFP FC levels are ok with them in terms of manufacturer warranty?
Are you using borates?I don't use the pH control much as my pools pH is stable
