I have an old Goldline system. No idea how old it was here when I bought the house ten yrs ago. In 2014 I replaced the Circuit Board after the thermister cracked. I found the part online for a third of what Hayward wants for one. I used part No. GLX-PCB-RITE (at least that's what's on the box). The board itself has several other numbers.
At any rate, here is what it's showing on the diagnostic control panel -
A steady 3000 for chorine content. I added 80 pounds of salt a week ago and the reading has not changed.
The "generating" and "super chlorinate" light will illuminate but...
The diagnostic button which allows one to scroll through the various setting does nothing. It stays fixed on 3000.
A check cell light that will not reset. The "press and hold for 3 seconds" reset does nothing. It never resets.
What do you think? A new PCB? They run from 175-800 bucks with most in the $350 range. Or, simply put a new thermistor on my OLD PCB? That's super cheap and I have a "guy" who does this type of electronics work just down the street.
Or, with a system this old should I consider starting from scratch with a whole new kit (controller and T-cell) for 1300 or just try and replace the PCB?
