- May 3, 2014
- 62,786
- Fiberglass
- Pentair Intellichlor IC-40
Absolutely.Oh i can do an FC test that way?
Extended Test Kit Directions Archives
There IS !!! FC/CYA LevelsIs their a chart that tells me what a safe level of FC to let my kids swim in?
We can assume you have passed all three criteria for a successful SLAM?My FC is at 9. Do I continue to leave the SWG off?
Yes I did pass all three criteria. My SWG has no PPM numbers on it. How am I supposed to know how much FC I’m adding per day?We can assume you have passed all three criteria for a successful SLAM?
If so, turn the SWCG on and set it to generate 3ppm FC per day. Test your FC every day at the same time and adjust the SWCG as necessary to keep at or above Target FC for your CYA.
PoolMathHow am I supposed to know how much FC I’m adding per day?
The manufacturer can’t have a clue what size pool you have. The unit will be used on many sizes pools and is rated by output. On a smaller pool the given output accomplishes more, on a bigger pool it does less.My SWG has no PPM numbers on it
Because after you get it set you will test and see what happened the day before and adjust as needed. Once you get it dialed in you will need monthly (roughly) tweaks up for the first half of the season as the UV increases with a higher sun and longer days. After the mid point of the season you’ll occasionally have to adjust downward as the UV demand decreases in the back half of the season.How the **** am I supposed to know how much FC I’m adding per day?
I looked but couldn’t find anything useful. This is it,PoolMath
I need to know what Solaxx model you have. The Retro is very small. Can you see if there is more information on the model?
