Green pool!!!!!
JimMarshall
1,090
Oil City PA
I ask because 20 lbs of dichlor will add 60 ppm CYA to that pool. Add in continued tablet use and I find 40 PPM CYA to not be a believable number.
If you’re keeping the pool at shock level per the cya, the algae will die. Period. Something isn’t adding up here, and in my opinion it’s the testing numbers. A good kit like a Taylor K2006 will tell the true story
Flying Tivo
2,183
Monterrey, NL, Mexico
Pentair Intellichlor IC-40
Can you please post pictures of the pool and equipment pad? If you are a pool professional what test kit do you use?
Ryscott
In The Industry
Jul 22, 2020
17
Kansas
I have a Taylor kit and Aquacheck silver strips. Don't have a pic of the equipment pad but it consists of Whisperflow 1hp, TA-60, 2 valves suction side one for skimmer one for main drain, 1 return line devided into 4 eyeball returns. 1 cut out Polaris pump, Pentair offline chlorinator and an old dog toy.
Flying Tivo
2,183
Thanks. You will be very benefited if you purchased a Taylor K2006C, which will help you in your job from here on. We would only be helpful if you post test result from this type of kit, FAS-DPD(we dont trust pool store test or guess strips). Any pool that has algae needs to follow a proper SLAM Process, to do so you will need to test the pool every few hours, not just 2 times a week. Please post a full set of test result with the Taylor K-2006C like this:
FC
PH
TA
CH
CYA
Salt
Reactions: Ryscott
Ryscott
In The Industry
Jul 22, 2020
17
Kansas
FC
PH
TA
CH
CYA
Salt
I will get a new kit and post results. This is a service customer not my home. Theres no way I can test every couple of hours lol. Thanks for the advice on the kit
