IceShadow
If the water isn't that expensive I would drop 1/2 the water and refill then continue to SLAM at 12ppm of chlorine, assuming the CYA is 30 after the drain and refill.
@bsmom07 signature says she is on well water. I would want to know the test results and quality of that water before recommending refilling. .If the water isn't that expensive I would drop 1/2 the water and refill then continue to SLAM at 12ppm of chlorine, assuming the CYA is 30 after the drain and refill.
Only issue I had when filling it last summer with well water was iron in the water which was solved with a 5 gallon bucket of pillow stuffing.Good point!
Last test logged was 15 days ago. That is not going to work. You need to log all tests every time.PoolMath Logs
troublefreepool.com
I’ve been following to best of my ability. The vacuums and brushes aren’t logged and neither is my CYA and TA tests from this morning. CYA was 60, TA was 90.
Sorry, I thought it logged the result of the test when I logged the addition. All of the additions are a result of an FC test. Test this morning was 14.5 FC. I added 136oz 10% bleach. Tests have been holding steady around 10.5 FC. I’ll attempt a better job of logging in Pool MathLast test logged was 15 days ago. That is not going to work. You need to log all tests every time.
Yes I did and I’ve ordered more for the FC CC since then.Did you order fresh testing refills at the beginning of the year?
