Results! Alright. Here's what I want you to do (with pump running):
1 - Lower pH to about 7.2-7.5 with muriatic acid. Do that first.
2 - Add regular bleach and go for an FC target of 10 PPM; Test again in 10 minutes! If the FC is 5-10 after 10 minutes, then go ahead and do item #3 below. If your FC disappeared to almost nothing, you have ammonia and need to keep adding bleach and testing EVERY 10 min until it holds to 5ppm or more after 10 minutes.
3 - After confirming there is no ammonia as noted in item 2 above, add stabilizer for a CYA target of 30 ppm
4 - Increase FC to 12 ppm and perform everything according to the SLAM page (link below).
From here on, until you pass the 3 SLAM criteria, focus on FC primarily for the first 2-3 days, then you can start checking CC, and maybe confirm CYA in about 3-4 days.
Good luck!
