Hi. I debated whether to put this in the algae forum or the pump/filter forum, but I figured since this is mostly an equipment question, I'd post it here.
Due to a series of family emergencies and a timer failure, I recently found myself the proud owner of a 10k gallon swamp in my backyard.
My system runs on a Hayward single speed pump and a DE filter with ONLY backwash and filter settings. No vac to waste, no recirculate. Nothing else.
I've hauled out most of the solid stuff and used a Harris H1572729 ProForce 1 HP Above Ground Pool Pump with my vacuum hoses to vac to "waste" (aka emptied it out to my driveway) most of the sediment from the bottom.
The problem is that I can't run the system installed Hayward pump/DE filter for more than maybe 30 minutes without the pressure spiking to dangerous levels. It's going to cost more time and DE money than I have to even start to make a dent.
I can use the Harris 1 hp for circulation while I start the SLAM but eventually I'm going to need filtration that I can use to "bypass" my DE filter.
Is there a cartridge filter that I could hook up to the Harris 1 hp with my vacuum hoses, without having to do any real plumbing?
If not then would something like the Intex Krystal Clear 2500 gph cartridge filter/pump combo work?
Any other better ideas?
Thanks for your time.
