Hi,
I am new to the website and first time house owner with a pool 16x32 23,000 Gallon water.
Since pool opening I had the alage bloom. After doing the SLAM process it's all gone. In order to clean the water I have used clarifier and then flucotant, it made the water clearer but green dust is there at the bottom. I did vaccum to watse on Sand filter. I am using Taylor Kit 2006. CC level is 0.5 and FC were around 4ppm. CYA is around 35. PH is 7.4. Overnight FC test was good too. Should I still be keeping FC level at SLAM level or I should just keep the FC at minimum level.
Right now I still see the green dust inside the pool and water is not crystal clear.
Please help Thanks.
Please help Thanks.
