- Jul 17, 2019
- 4,070
- Plaster
- Pentair Intellichlor IC-40
I would keep it at SLAM level and keep hunting for the algae. Have you scrubbed weir doors, behind lights, etc?
I've seen many people in your position and the algae will keep coming back until they find it, scrub it to remove its protective film, and let it be killed by chlorine. Some of my favorite posts are when they find the culprit and can finally end the SLAM, like these:
www.troublefreepool.com
Found the hidden algae
My pool water has been clear but my fc usage has been too high causing me to run my swg IC40 at 80%. Also, getting a lot of milky debris coming off the cartridge filter when I clean it. So, from past experience and comments here, I knew there must be algae hiding somewhere in the system. It...
Algae behind pool light
After a couple of days of SLAMming and not passing the OCLT, despite crystal clear water and no CC, we decided to look behind the light. Bingo. It was quite gross behind there. We brush the nook and left the light out for a couple of hours with water at the SLAM level. Then my husband spent...
Found algae under main drain cover. Can I remove?
SLAMMED a month ago, but have had a couple small algae spots come up if I don't brush the pool for 4-5 days despite very adequate FC levels. They brush away easily, but obviously it meant I didn't get everything. Anyways, decided to investigate more closely under my main drain cover, and what...
Algae living in plastic stairs
I have been continually fighting algae in my pool. I shock and pass the OTC and then in a week the algae is back. I just noticed that in the support tube for my ladder in the pool, it is bright green. I then inspected the tiny holes in each step and they too are bright green. Now I am taking the...
