Greece in Georgia - Taking Bids
kimkats
46,788
Tallahassee, FL
another thing I LOVE to do is swim in a Spring shower with no lighting around of course. It is so neat to be under the water when it is raining! OH jumping into the pool after or during mowing the yard!!
kimkats
46,788
Tallahassee, FL
Do you think they are done? When you think they are done you have your first "job" as a pool owner.......take the plans and a tape measure out to the pool.....is it wide, deep, long, etc enough? Add about 8" for the steel, shell, and plaster. NOW is the the time to fix/tweak!
Kim:kim:
Reactions: TecHHeadDD
TecHHeadDD
Active member
Feb 1, 2020
28
Bold Springs, GA
Nice clean dig they got a good operator. Tape measure all of it as suggested
Measured 53" to the center of the skimmers from the floor of the excavation. Water depth desired is 48", which leaves 5" for rebar and concrete on the floor under the pool floor. Does that seem appropriate?
Width of the excavated walls measures 20' but the contract calls for a 20' wide pool. Once rebar and concrete are applied to the walls there may be as much as a foot less width? Am I missing insight on industry standard as to what constitutes width - actual water width inside or the form of the pool outside the walls ?
jimmythegreek
In The Industry
Aug 10, 2017
2,844
Morris Cnty NJ
theres gonna be more than 5" when gunite guys are done. its kind of common to have variations the guys just slam it in and the measurements are rough. hes gonna offer to take a little money off the price instead of fixing it. fixing it is a pain in the you know what
TecHHeadDD
Active member
Feb 1, 2020
28
Bold Springs, GA
Roger that. Had the site manager out, and it did turn out that the width was cut to form not to water width. A failure to communicate. They'll back out that cost. I don't want to start from scratch. Turns out with people trapped at home for the summer, they've been up to their elbows in calls for pools. For now I'm at the front of the line. 18 x 42 will be livable.
