Guys, I have owned my home with an in ground vinyl pool for about a year now. I use the BBB method, have a Taylor test kit, and a sand filter... I'll admit, it took a little reading and learning, but I can maintain crystal water thru out the 95+ degree summers here in south Georgia with relative ease using the BBB method and adjusting filter times thru the year. So here is what happened... water level started dropping during December, wasn't really able to gauge how fast because we had a really wet month + I did some traveling. Eventually water dropped below the skimmers so I stopped running the filter to see if maybe I had a cracked pipe. Eventually I cleaned up the levels and found a hole in the liner. I tried to jump on it and made some calls around to get some price estimates. Settled on a local store that had the price, warranty and package. 20 years experience. Went into the store and thats when they started questioning me about my water balance. I told them I have no problem maintaining the pool unless I leave for a week or so during the summer and don't cover the pool (chlorine burn off due to sun exposure). Thats when he tried to sell me on the Pristine Blue copper ion chemical. He told me everything you would want to hear. Easy, almost maintenance free, safer, cost less, he would test the water for free, yada yada yada... Sounded great so I came here to read up on the product. I'm going to make sure he doesn't balance my pool when he is done with the liner. There are 2 or 3 things I would like opinion on, and best practices with my new liner.
1) I read that water hardness is not so important with a vinyl pool. He said if I don't pay attention to the water hardness (what he referred to as calcium and alkalinity) then the liner will get brittle and crack. I keep my TA around 60-70, but never measured my hardness or calcium after filling the pool. Is there a number I should strive for on a vinyl pool?
2) I told them I use liquid chlorine and that my liner was faded most near the jet where I pour in the bleach. Should I continue to pour in near the jet when I get the new liner, or disperse around the edge slowly? Skip that and just go straight to the skimmer? They recommended diluting in a 5 gallon bucket before pouring but what your breath
3) This seemed absolutely ludicrous, but he said go around the top part of the liner above the water with armor all. This would prevent the upper part of the liner from fading.
He said if I do the armor all, keep the water balanced per his computers recommendations, and use pristine blue my liner will look like new in 20 year. Obviously I want the liner to last as long as possible. What do you guys think about my first trip to the pool store?
