- Nov 12, 2017
- 12,657
- Plaster
- Pentair Intellichlor IC-40
Spring is typically the time of year I need to top off my CYA. So I set up a repeating calendar event to ping me on the first Monday of February, each year, to check my supply of CYA. I happen to be low this time, so I just ordered some more. I set the date a bit early, just in case CYA happens to be in low supply. Gives me a month or so to find some.
How's your supply?
Speaking of reoccurring calendar events, I just recently added a weekly one to test my pool light's GFCI outlet. I don't regularly test any GFCI component, and never have. Just one of those things I don't think about (but should, of course). Following the advice I gave someone else here, if there's one to test regularly, it's the pool GFCI! So now I do. It's now part of my regular weekly maintenance, and considering the outlet is inches from the other things I use during my maintenance routine, and the fact that it takes seconds to test, it's pretty silly not to...
How's your supply?
