Hello everyone. Thank you all for your time. I confess, I wasn't testing and doing what I should be doing. I'm a new above ground pool owner.
my set up - 6000 gallon above ground vinyl pool
filter intex sand pump filter with salt water chlorinator
tester k-2006
I had the pool for a couple months, and I assumed because I got a salt water chlorinator . Everything would be magical and I wouldn't need anything but salt. I failed. My pool is not clear anymore. The system seemed to be doing fine. I would occasionally have to add some chlorine after swims to bring it back up.
Lately I've been finding what seems to be a lot of dirt on the floor. I'm hoping someone can tell me if it could be something else. I'm not sure if I vacuum it, that its going through the filter and coming right back out??? Because i swear it will be back on the floor the next day. Not as much but its there. I doubt there is that much dirt flying everywhere.
Things i'm dealing with. Bees and mosquitos going in pool. Possible bee pollen? Should I use the cover???
It also looks like I have some kind of algae :/
Here are my test results from the pool. I left for a week with no maintenance and came back to this. I'm about to go to pool supply store so i can try and save this water. Any help or advice will be good.
Cya-about 40 ppm (I had a pool leak, i'm wondering if this is why this has gotten low or maybe because my ph is high.
Free Chlorine - .2 parts per million ( I know thats bad, I don't know if my chlorinator is working like it should be or if its because cya is low.
Combined chlorine -0
PH 8.0+ (I just added about 1 lbs of Dry acid sodium bisulfate to pool. My calculations said i need to add 2lbs 6 oz)
alkalinity test-TA - 240 ppm
Calcium hardness -230
i'm not sure how my ph and alkalinity got so high, i'm currently trying to bring it down. Last time I spoke to someone at Lesleys pools they said because we have really hard water here in our city.
last question. I bought a used intex filter that was only 1 year old, The sand was a little below the minimum sand level. I'm thinking I should replace the sand with new sand. Maybe this is causing some issues. Long post I'm sorry. Maybe i'm just venting.
tester k-2006
