I just replaced my T-15 salt cell with a compatible generic cell I purchased. Install went well until I plugged it in and started the system. I keep getting a High Salt/Amp error. I took a pool sample to a local pool company and they said my salt content is 4800. I added stabilizer, alkalinity increaser and liquid chlorine. The tech said I may need a new board. I have been on You Tube and forums trying to problem solve. I was able to run a diagnostic and as you can see from the picture below.... the salt is in fact too high. What would my next step be? How do I know if I need a new board or just need the salt level to be lower before the system works again? I did check the cell configuration and it is set to T-15. I saw on a thread in this forum that you can have a short in the K1 solder point. How would I be able to check this? Any help is greatly appreciated. This is definitely out of my expertise.
