jark87
- Jun 5, 2011
- 1,317
- Plaster
- Jandy Aquapure 1400
I agree that you should be seeing a more significant drop in temp. Our dew point was 69 today, so DFW is slightly more humid than your dew point of 67. As far as electricity goes, the chiller doesn’t consume very much. It’s one of the reasons I selected it over a heat pump/chiller combo, which consumes electricity similarly to an AC unit. The primary electricity consumption of the chiller is just the fan running. It’s minor, but of course, the pump has to be running when the chiller is running, so that’s where the electricity consumption rises. If you have a VSP, it’s probably less of an issue for you as you probably run 24x7 anyway. I still have a single speed pump, so I’m adding 4 hours of pump run time. For me, it’s worth it, because I’ve been able to reclaim my pool. It’s 102° today and my pool is a refreshing 82°.that's a lot of electricity to use to fight off only a couple of degrees.
