- May 16, 2011
- 1,180
- Plaster
- Pentair Intellichlor IC-60
They will be helpful when the water temperature falls below 60 degrees and the SWG quits working. They can also be used when you need to add a small amount of CYA but will not be very helpful to raise your CYA to the 60-80 ppm range you'll eventually need. You will need to use granular CYA for that.
It won't hurt anything to keep them but you will not likely go through the entire bucket for many years. A smaller one may be better for you in your situation.
Another option is to use liquid chlorine as Matt suggested but that will require more testing and daily additions of chlorine which may complicate things for you during the startup. The pucks really take a good chunk out of the workload.
Thanks, Brian. That's kind of what I thought, but the thrifty side of me took over and I wanted to get more bang for my buck! I saved the receipt and will return them. What size do you recommend as a good balance between value and not overdoing it?
