- May 23, 2015
- 24,447
- Plaster
- Pentair Intellichlor IC-60
The CH drop and TA rise is surely related to the Startup-Tec as well as the Jacks Magic added (as if Matt could ever be wrong). Given your current pool chemistry numbers, a TA rise is not really possible without an outside upwards means of influence. Keep us posted on your numbers. Everything you have done so far will prove to be very beneficial.
Is it possible that the TA could have potentially been raised too high near the completion of the fill?
Regardless, the numbers you have mentioned are not far enough from the realm to normality to cause too much concern. Keep up with frequent testing and things should somewhat stabilize very soon.
Yeah, I forgot about the TA rise. Most of these sequestrants are high pH solutions that use sodium hydroxide to increase pH. So if you add the the sequestrant, I would expect the TA to increase as well since you're adding excess hydroxide (OH-). It'll all go away as you add acid so no worries.
