- Feb 2, 2023
- 42
- Plaster
- Jandy Truclear / Ei
Just a quick update. So I received my leak / dye kit. . Turned off the pump, and waited till the water was fairly still. Released the dye around the returns, light (have one), skimmer area, and all possible leak areas my wife and I could think of/see. Nothing!
I couldn't get close enough to the two (2) main drain so I still need to check that area. In any case, I won't go into detail, I ran my pump at a higher RPM and it started shooting out clouds of dirt in the return! I figured, I think I forgot to rinse after the backwash
Since I still have 3 gal. of chlorine, I started the SLAM process again
R-0871 is only good for one more test
I'll be starting another thread with my leak issue.
