First.......breath............we got ya! We CAN get you through this!
Okay you have the equipment so all is good and things will go smooth from here.
The acid wash people........They will know someone that can help you get the equipment finished. They all know each other and know who does good work.
Some questions to make sure we are all on the same page:
-Is there power to the control box?
-Is there wire run to the equipment pad?
As soon as they do the acid wash you need to start filling the pool. Here is a link to how to start up plaster (talk to the acid wash guys about when you can swim in the pool):
Pool School - Start-up New Plaster
NOW the hard part.......if there is no power to the pumps they cannot run SO you will need to find a way to move the water until you can get the pumps running. You can buy a sub pump for cheap at Harbor Freight or someone may have one you can barrow. You can and should set the sub pump up so it moves the water around the pool. When you add chemicals you should stir it up good with a straw broom with the sub pump running.
That will buy you some time to get the rest of the ducks in a row.
Do you have a test kit yet? If not look in my siggy to find the one you need. Until get the good one in you can get one of the cheap drops tests from Walmart. You need to be able to test:
-PH
-FC (free chlorine)
-TA (total alkalinity)
These are must have tests for starting up plaster. You will need the other tests soon but these three will get you through until the good test kit comes in.
Girl! I HATE this for you! How scary and sad........just think, you started out to do a OB then switched to him
Do you have a restraining order against him and his family?
Let us know what you decide to do and how else we can help you!
