Hoping to get some recommendations on a heater for an upcoming build I have. Specifically, one that fits the bill for the following (I am aware some info may be irrelevant for a heater). I am also curious if this is an easy add on after the fact if I know a plumber. I am not keen on buying from my builder because of their upcharge on the heaters. I was just going to have them leave some room on the pad for one in the "future".
- 16x30 rectangle vinyl pool
- Intelliflo pump
- EasyTouch 4 with Screenlogic2
- 24" sand filter
- Located in Michigan
- Heating up quickly is not too important to me. If I can have a lower BTU heater that is more efficient I would be happier with that
Let me know if you need other information in order to make a recommendation.
Also, one last side question. Is a heater the main source of water temperature information for an EasyTouch? Or is there a temp probe in the intelliflo pump or something?
- Intelliflo pump
- 24" sand filter
