My Ray-Pak 400k makes an expansion noise, kind of a single light bang, every few minutes when running. I understand why it would do it if the flame were cycling on/off, but the flame is on all the time.
Just strikes me as odd the way it makes a noise like that when the water flow and flame are consistent. Probably does it every minute or so. Similar to sound if you were to tap on the outside cover for the heater, not a tic, tic tic type expansion noise.
Been doing it the last couple of seasons. Any ideas other than the obvious expansion of the manifold?
Edit to update:
After using shop vac to remove some leaves and then reversing the vac to blow around inside the heater it is no longer making the noise.
Not sure exactly what I did to fix it, but cleaning did the trick.
Thanks for your help!
Edit to update:
