Idk, if I would continue to shock at this point, until you decide what you are gonna do...
{I know that traditional wisdom is Cl loss is organic or sun... But in the face of a baqua conversion+ CDX situation, that statement may not be so clear-cut
So absolutely, you need to keep FC above the min for CYA-- but to my mind, shocking is a waste, especially if you end up just draining and refilling soon. You did say there's no visible algae, right? Any slimy-feeling or slippery patches, even if you can't see any discoloration?....
To cover all the bases: did you clean out every, sneaky hiding spot for the bacqua-nasties, or algae (behind lights, in ladder tubes, etc.)?
I know it's hard to believe when you keep having to buy so much liquid chlorine, but it will be cheaper in the long run.
One pink slime &/or white mold outbreak, and you would spend more on bacqua products than a year of shocking* with Cl would cost ---And it would probably never really be gone...
Once you are over this new "bump", you too, can have (and keep) a clean, safe & pretty TFP.
*a year of shocking would never,
ever be necessary... The comment was (slightly) exaggerated & for comparison purposes....
As for vacation:
ChemGeek, could they add some P-60 (so they don't come home to an algae pit), put the cover on the pool and deal with everything when they get back?
