Just a quick note that the results will be the same either way, but if you follow the 0.2 directions you will use more reagent, but get a more precise result. Using the 0.5 directions you use less reagent, but your result is a little less precise.
For example, say your FC level is 5.
For 0.2 you would take a 25mm sample of water, use two scoops of powder, and then use 25 drops of reagent. 25 times 0.2 = 5ppm of free chlorine.
For 0.5 you would take a 10mm sample of water, use one scoop of powder, and then use 10 drops of reagent. 10 times 0.5 = 5ppm of free chlorine.
Typically it’s not necessary to get down to 0.2ppm precision to manage your pool, so you can manage your pool using the 0.5 option and use less reagent.
This makes more sense Thanks
