The “tips” were not meant to scare you but to be prepared.
I have the same SWCG - around a water temperature of 50 degs the SWCG will not operate. So once water temperature drops below 60 degrees prepare to add LC. Have some on hand.
There are 2 plugs on your pump. One is below the pump basket an other is below the impeller housing. Usually both are on same side of pump.
The heater plugs are near the inlet pipes of the pump.
The filter is a very large plug or valve.
