So I've been busy SLAM-ing (well, almost). More as a test run than anything because I have to drain next week to move the spa a smidge and have the heat pump installed.
Left the chlorine to drop back to normal. Measured Cc. 0.9
I mean what the...?
Either my tester is not measuring TCl accurately or my reagents have gone bad or I don't know. I have no way to reliably measure Cc while Fcl is over 8 so I know when I'm done. I mix with half distilled water but that gives me inconsistent results so I'm not gonna base anything on that.
I'd get a drop test from the US, but seems nobody ships them overseas.
Water looks great tho and no chloramine smell, so I'm not too worried, especially since I'll dump and refill next week.
Lastly, I have a question on TA. Last week, 2 days after adding borates, it measured 71.
I've since added only dichlor then bleach and dry acid. Measured TA yesterday: 82. Added 30g of acid because my ph was a bit high as well. One day later, my TA is 83. I've also added about 200ml of bleach 5% during this time, but that shouldn't have an effect on TA.
Yesterday I added another 43g dry acid which brought the TA down to 55 and Ph to 7.4
Measured this morning (have not added anything in between, only have the swg running), TA is 32?!
You can see my logs here:
PoolMath Logs
What caused the TA to rise and then why did it drop so much? Even with 0 borates, 43g of dry acid should drop the TA a maximum of 16ppm.
Ps: let's assume the tester is not accurate. But I can clearly see the significant color changes after adding the reagent: from blueish green at the higher end to light green at the low end. You measure this stuff daily and you can estimate the value by the color of the solution.
Edit: turns out... Never have two similar jars when measuring. I use one for adding chemicals, and one for distilled water that I use for cleaning the stick I crush the tablets with. Turns out I picked up the wrong one which must have still had some leftover dry acid in it. I cleaned everything and remeasured and TA is at 55.
