I am not understanding. Is you plumbing done and turned on and running? The pumps freeze protection will run the pump if the temp is cold enough to keep it from freezing. If there is no pump, then you might have a problem.
In a pressure test all the pipes are connected, sealed together, filled with water, and pressurized with a pressure gauge on it. You leave it and the pressure gauge tells if there is a leak or some trade nicked a pipe. You leave it pressurized until final plumbing is done.
I would drain the pipes before freezing conditions and repressurize when it warms up.
