Hi,
we have a pool/spa built in 2019 with all Pentair equipment with the Intellicenter.
My problem is with the freeze protection. Whenever the temperature reaches 35degrees
all pool pumps come on. They stay on for about 30 seconds, then turn off.
30 seconds later all pool pumps come on, and so on ...
It seems that here in Northern California, 35degrees is a common at night temperature in winter.
When the temperature reaches 34, all is on and stays on.
When the temperature reaches 36, all is off and stays off.
The way that I am currently addressing the situation is that when
the weather forecast indicates close to freezing temperature, I change
the air sensor calibration to indicate less that the real temperature.
When the forecast is otherwise, I change the calibration to indicate more
than the real temperature.
Pentair customer service advised the following:
. reboot the panel
. check the software for latest update
which I have done to no avail.
Any advice is appreciated.
. reboot the panel
