Hello all! Hoping I can find some help or direction to an issue I am having. I am in central OK and our weather is up and down during the winter. Our inground pool has an attached hottub/spa that overflows into the pool during typical operations. During the winter we utilize the freeze guard protection that is part of the system. In addition to the freeze protection I typically cover the equipment and include some heat lamps under the tarps for some added help. Recently I've noticed that when the freeze protector switches from pool to spa, the heater kicks on. I can hear it and see it that it's running in the Pentair app. I can turn it off in the app, but it will continue to kick back on. I've read where running the heater during these winter spells can damage the heater, not to mention being under a tarp with little ventilation. When it's not freezing temps, I have a schedule set in the app for the spa to run an hour a day by itself to circulate and sanitize. Could the scheduled run time be a part of this issue? It's like the water temp is below the minimum temp of 40 degrees in the app so the heater kicks on automatically during the freeze protection. I've mostly ran the entire system through the app so the panel is a little foreign to me. Definitely will take all the help I can get to avoid any future damages. Thanks all in advance!
