- May 16, 2022
- 22
- Plaster
- Pentair Intellichlor IC-40
I live in TX and have freeze mode enabled on my Pentair system, which seems to work fine on the pool and spa. My pool and spa are run off the same pump so freeze mode is only enabled on the pool circuit. The problem I'm having is when my daily schedule kicks-in. The daily schedule triggers a higher RPM on the pool which is ok, but when it switches to spa mode, the spa drains.
Is there a way to disable the daily schedule when freeze mode is active? If not, any ideas why my spa would drain when it transitions from freeze mode to daily schedule? I have two actuators, which I'm assuming is the source of the problem. TY.
