- Feb 17, 2024
- 2
- Plaster
- Hayward Aqua Rite (T-15)
Greetings TFP! First post here so let me start by saying how grateful I am for the wealth of in depth knowledge provided by the members on this site
I recently bought a TF Pro test kit and have enjoyed implementing the TFP methods. The pool has never looked better!
My question relates to redoing my pool plumbing but first, a little context: We bought our house with a pool a little over 2 years ago and I quickly replaced the old single speed pump with a VSP and replaced the chlorinator with an SWG (pad is pictured). When I replaced the old pump with the VSP I just dropped it into the existing plumbing lines and unions. I’ve recently realized that my main drain line is run with 2” pipe right up to the pad which is reduced down at it’s 2 way diverter valve. The pipe continues from the valve to the pump as 1.5”. The 2 additional suction lines, a skimmer and cleaner port, are 1.5” from pad to pool. The single return line is also 1.5” from pad to pool.
So my question is this: would I see any benefit in replumbing this pad using 2” pipe on the suction side? I’m picturing 2” pipe for the main drain to a 3 way valve which continues as 2” to the pump. I’d keep the 2 other suction lines at 1.5” into another 3 way valve, at which point the pipe upsizes to 2” to meet the main drain 3 way valve. I also figured I go with 2” pipe from pump to filter and from filter to SWG because… why not? Is this a waste of time and money? If not, is there any better alternative approach? Any insight from those who are knowledgeable in hydraulics would be very much appreciated!
